Old Jan 22, 2015 | 04:08 PM
Mrmiata's Avatar
Mrmiata
Default Re: Fuel pump or Fuel pump relay?
You should be able to turn the key to the "run" position - two clicks over without going to "start".. and you should be able to hear the fuel pump run for a second or two. Might help isolate whether this is fuel or CPS related. Reading the check engine light code would also be helpful.
