Old Jan 23, 2015 | 09:30 AM
Padgett's Avatar
Padgett
Default Re: Fuel pump or Fuel pump relay?
Most GM cars have an "Assembly Line Prime Connector", a wire with a green connector just loose under the hood that goes directly to the fuel pump. Very handy for troubleshooting as you can put power to the fuel pump without turning anything on or monitor for power when you turn the key. Does the Crossie have anything like that ?
ps if the engine shut down "like a switch" the problem is usually in the ignition or the fuel injector circuit. A fuel pump or clogged filter will usual struggle a bit.
