Old Jan 25, 2015 | 06:16 PM
  #778 (permalink)
eatmycrackers's Avatar
eatmycrackers
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
So I did the fix and followed the instructions drilled out pin etc. I reinstalled and made sure all of the connectors are in place. Key turns but when I go to crank the car the car dies and I have to reconnect the battery. Transponder ring is connected at the plug (has to remove speedo to confirm) and does not look damaged however does not light up green as I have heard some mention. Do I need a new transponder ring? Car turns on fine until ou try the engine and it just cuts all power and dies. Need help PLEASE!
