Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
I would check the pins in the connector & make sure they are lined up in the plug on both sides. Looks like the transponder ring is not getting voltage. Also check voltage across the car side of the connector with the key turned on. Just guessing.
Stan
