Old Jan 25, 2015 | 08:54 PM
  #780 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Red Runner
I would check the pins in the connector & make sure they are lined up in the plug on both sides. Looks like the transponder ring is not getting voltage. Also check voltage across the car side of the connector with the key turned on. Just guessing.
Stan
I am not sure it gets voltage as such, as it is basically an transmitter/receiver kind of gizmo picking up the returned signal from the chip in the FOB which it activates with a signal.
It does not light up green or any other color, at least mine doesn't.
