Old Jan 28, 2015 | 03:22 PM
  #38 (permalink)
onehundred80
Default re: Kennwood D562BT to Replace OEM Infinity w/o Nav - easy install
Originally Posted by Mrmiata
Here I thought you knew the Nav unit was a different antenna adapter than "non nav".. I had caught that in some thread a while back. Anyways I went to Crutchfields and plugged in "with nav" in the car specific stereo boxes.. and they show this as the antenna adapter..??.. Metra 40-VW12 Antenna Adapter
That part does not have the length of wire between the two connecters, the two different connecters being in the same body. It would be neater but as it does the same thing with no dollars spent I'll live with it.
I'll amend my post to reflect the difference. Thanks.
PS
I forgot to mention that I knew the adapters were different, I have been here a few years more than you, over 5 years and you obviously missed my thread on the conversion from the stock radio to the Nav radio. I did the connector swap at that time, so I knew about the difference.
