Kennwood D562BT to Replace OEM Infinity w/o Nav - easy install
Jan 29, 2015 | 11:07 PM
41
permalink
onehundred80
Apr 2006
25,432
647
Ontario
re: Kennwood D562BT to Replace OEM Infinity w/o Nav - easy install
Quote:
Speedy4x4
Next is the change to the pyle dvc rear subs. 180
Where r you routing your mic?
I ran mine right beside the rear view mirror bracket, can't tell it is evan there blends right in.
That would be a good spot, I have not started on it yet - too cold, maybe tomorrow.
I think I will try to get the wire down and under the carpet instead of taking it through the fuse area. I'll see how much cable there is to play with.
Running it through the fuse panel door you have to be careful otherwise it may interfere with dropping the lower dash which takes the light switch with it. So you have to be careful that it goes over everything and not through something that comes down with the panel, the silver brace visible through the fuse door is one to avoid.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
