americanretrodave
"After 3 failed attempts to start you will have to unhook battery for 10-15 min. Before you can try again, you can only do that 10 times before the car ecu becomes unusable 30 no start self destruct."
The above is what I've been told. I'd try the cps it's cheap and easy to replace, if that doesn't work, I would guess the skreem, but I doubt that is it.
Dave
(A) I've never heard a 10-15 minute unless your trying to do a full system reset. Just disconnect momentarily and reconnect is all I've seen.
(B) First time I've seen a 10 count posted also.
(C) Do not hit a 30 count has been repeated several times.
