Old Feb 5, 2015 | 07:39 AM
  #44 (permalink)
wvwonder's Avatar
wvwonder
Default Re: DIY Rear Cambers
Great thread, my problem is the front camber, my front camber is -2.4 left and -3.6 right . That's over 2.1 away from spec. Will the Fronts only require the install of the eccentric alignment bolts. .Will the aftermarket/OEM eccentric bolts that allow +/-1.5 degree adjustment be close enough to spec. Using part number :2023300118.
I know the K-Mac would give more but that's more than I would like to spend. I
Just want tread life and safety
Thank you for any help you can give me.
