Re: Flashing low fuel indicator lamp
Travish
Today When I pulled up at the house, I looked down and the low fuel lamp was flashing. Tank was 1/2 full. Cap on tight. When I started the car the next time the check engine light was on. I checked the pdf manual here and it says nothing about the lamp flashing only on steady. I did not have time to go to Advance/Auto zone to have code read. Anyone have any ideas.
Thanks
If you try to squeeze more gas in the tank when full after the pump clicks off can cause the fuel light to flash when it gets down around 3/4 to a 1/2 tank. Overfilling it causes the fuel to get in the evap system. If the gas cap is bad it can also cause it.
