Old Feb 14, 2015 | 07:22 PM
massanu's Avatar
massanu
Default Double Din Project
UPDATE 06-26-2015
PROJECT FINALLY DONE !
- 2005 SRT-6 AeroBlue
- Nexus 7 2013 Wifi Tablet
- Backup Camera, Display when Reverse shifted
- Sound Wired to car speakers
- Mobile Hotspot to share 4G to Tablet via Wifi
- USB Hub to add other devices
- Bluetooth Control for Music
- Start when car ON and Stop when car OFF
- OBDII bluetooth connector to use with Torque PRO
And last but not the least:
- Tablet is removable anytime by sliding it. So I can bring it home to make updates
06-29-2015
The only problem remaining is to bring the rearview camera cable from the trunk to the center console in a hidden way
Here are the pictures:
Little bonus, when I shutdown the car
Hello all,
I am on a project of installing a double din solution on my Crossfire SRT-6 Aero Blue
Right now I have trouble with 2 thing:
- Installing the RearView Camera
- Adding a power source by adding wire circuit from the fusebox to the inside of the car
My questions are:
1 - How to pass the cables of the rearview camera from the license plate to the inside of the trunk ? I checked and I did not see an easy way to do it
DONE
2 - How to pass cables from the underhood fusebox to inside the dash bezel
I changed my mind, and will take the power directly from the ACC wire from the stock harness
3 - How to plug RCAs cable to the stock harness ?
I am looking to plug a USB DAC (
USB DAC USB DAC
) directly to the stock harness to output the sound of the tablet to the AMP
Any guidance ?
Its a very exciting project and the first one on my Crossfire, so I dont want to mess up
Thanks you guys
When the project will be done I will post pictures for sure
