Old Feb 17, 2015 | 03:31 PM
ajr's Avatar
ajr
Default Re: vacuum tap point for gauge, n/a
I know you can get vacuum from the line that runs across to the driver side fender well and connects to the evaporator purge solenoid mounted there. ( it's the hard plastic line that has a rubber end on it at the solenoid. )
( I know this, because I have left it disconnected by mistake before, and the engine is NOT happy. )
I had a vacuum leak when I changed the throttle body haha its no fun! Any chance you have a picture? I'm at work and will most likely look for it on break
I also read something about a "small hose from the valve cover vent caps"?
