Re: Key Fob Issue
Tried locking and unlocking with key and it not works with the driver door and nothing else. When I turn the key on and use the consol button nothing happens. Nothing also happens when I press the tow button. Light is permanently off. Removed the Rcm took it apart and noticed the typical crapy solder joints, I soldered whatever joints didn't look great, put it back together started it up and nothing changed...
I also tested the yellow and black relays in the fuse box and they both performed as supposed to.
So now I am not sure what the heck to do.. Perhaps if I could get my hands on another pump module it would be a good test to see if it cures the problem..
Any advise would be great...
Thanks
