Key Fob Issue
Old Feb 22, 2015 | 09:15 PM
MB04XFIRE's Avatar
Default Re: Key Fob Issue
From what I remember it only opened the driver door. Didn't open the passenger. Not even if I would lock and unlock twice with the key. And didn't open the hatch.
I will head to the shop shortly and try the consol button again and the key too.. And try and pull out the relay module and check it out just because
Old Feb 22, 2015 | 11:33 PM
MB04XFIRE's Avatar
Tried locking and unlocking with key and it not works with the driver door and nothing else. When I turn the key on and use the consol button nothing happens. Nothing also happens when I press the tow button. Light is permanently off. Removed the Rcm took it apart and noticed the typical crapy solder joints, I soldered whatever joints didn't look great, put it back together started it up and nothing changed...
I also tested the yellow and black relays in the fuse box and they both performed as supposed to.
So now I am not sure what the heck to do.. Perhaps if I could get my hands on another pump module it would be a good test to see if it cures the problem..
Any advise would be great...
Thanks
88stevie
19
Jan 21, 2026 01:46 PM
glover
U.K.
Oct 1, 2015 03:34 AM
UrbanE
Jul 16, 2015 01:39 AM
66L72M21
Jul 15, 2015 04:23 PM
Fildo Dog
Jul 6, 2015 05:20 PM
