rscrogg
I got the Schrader sensors at Discount Tire (a national chain) for $60 each installed. Problem is their computer couldn't program them and I had to go to the Chrysler dealer. They needed the numbers off the sensors, so back to Discount Tire to remove tires and get the n mbers, then to the dealer, which charges $95 to program the 4. Should have just taped over the light. If you buy sensors, get the numbers before they are installed!
Didn't think you were in for the cake walk you thought.. but thanks for the ID tip on them.. I was under the impression activating them with the magnet and working in sequence around the car would work (car would pick up signal and log as you progressed).
Now I'll be sure and log the ID's prior to install.. AND WHEEL DISPUTE IS DONE! We have a letter stating so.. and now it's time to find a local dealer that will get us fixed up with a correct paint scheme
