crysireland
Ok now im even more nervous....i would've never pulled the wires ... wouldn't have crossed my mind.... but ok, I'll do it
... obviously the tony little lids need to be open then...
NO, not the "wires" but the wire "connectors" are to be removed.
"pull by the wires" means to pull the assembly up out of the big plastic box by grabbing the whole assembly wires and all to get it free, then disconnect the connectors to free the RCM from the harness.
1) Open the Control Module container box.
2) Push any wires on top of the RCM aside to access the RCM.
3) Grab the RCM wire loom and gently lift the complete assembly out of its nesting hole, tilting the front side up first.
4) Pull the RCM assembly free of the box and other wire harnesses.
5) Disconnect the wire connectors from the RCM. (all are unique, order of disconnect not important)
6) Open and repair the RCM
7) Install in reverse order #5 - #1
