Re: HOW TO replace headlight bulb. Pictured step by step instructions
Be sure not to touch the bulb itself, the oil on your skin will cause it to overheat and shorten the life of the bulb. if you do touch it rubbing alcohol will clean it off. I made the mistake of removing the clip accidentally... so off to the garage I go.
