Old Mar 8, 2015 | 10:48 PM
  #248 (permalink)
onehundred80
Default Re: Crankshaft Position Sensor
Originally Posted by jrd1074
Thanks for the info. I will remove the plate first, because with the plate in place, I cannot get enough of a grip to remove the wiring from the CPS.
You can undo the bolt without removing the connector and disconnect it when it is more accessible.
