Old Mar 12, 2015 | 11:28 AM
Jlgo2011's Avatar
Jlgo2011
Default Re: 74mm throttle body problems
Originally Posted by carl graham
Same symptoms... rough idle, shaking. It did , however clear out once the rpms came up...low rps...symptoms back.It took it about a week to clear up.BTW, the car was/is drivenl daily...Good luck..Carl
Well thank you for your input. I was tempted to put the stock tb back on but since it worked for you I'll give it a try. Again, your help was very much appreciated.
