Hello 180, I re read your post and you acknowledged that with window fogging, you have the same issue I have. Yes, sometimes when humid (or hot air from engine comes up through the defroster when first turned on?) and cool outside, this does occurs. I am not aware of any water leakage, no damp carpet, etc. in my CF. I have not looked under the CF for water dripping, but will do so once warm weather sets in and a/c is needed. Can't wait! I have found that turning the blower on full blast on a/c and directing full airflow to the defroster does knock out the condensation fairly quickly, especially if I'm driving. I do this immediately upon any fogging. If highway driving, I'm a dead CF owner. I puller over one time early on before I determined how to eliminate the fogging- quickly. I'm not so sure I have the expertise to dig into the cowl area and look for hoses that may be blocked, but I'll try anything once. I don't have a small gear puller. I may be confident to poke around maybe remove the cowl but beyond that, may be beyond my pay scale. Thanks for your suggestions! I'll use your pictures as a guide- THANKS!
