rmcdaniel12
Im in the process of installing the SL55 Pump, high flow fuel filter, and AEM fuel regulator and i wanted to know the best position to put the fuel regulator. Rob is saying to mount it to the stud of the body but i dont have a nut to hold it in place. Yes, of course i can go buy one but in my mind set i think it should be included with the kit. The location im thinking (for regulator) is the stud just above the -/+ terminals of the fuel pump. Also, does anyone know of a trick to get the fuel lines on easy? Spray some kind of lube? With the limited about of space and laying on my back that s*** is a b****.
Yes...its not easy on your back. One of the lines is very difficult because the ID is smaller than the inlet. I put the regulator just rear of the pump, parallel to it. I just put my cover on last week or I would have taken a pic then, Be careful when you install everything that you take into consideration not to obstruct the re-installation of the cover. This is the perfect job for working under a hoist. Be sure to relieve the pressure at the rail connection before removing any lines or prepare for a face wash of gas.
