Old Mar 13, 2015 | 08:31 PM
rmcdaniel12's Avatar
rmcdaniel12
Default Re: any1 have pic of fuel reg installed by pump?
Yes...its not easy on your back. One of the lines is very difficult because the ID is smaller than the inlet. I put the regulator just rear of the pump, parallel to it. I just put my cover on last week or I would have taken a pic then, Be careful when you install everything that you take into consideration not to obstruct the re-installation of the cover. This is the perfect job for working under a hoist. Be sure to relieve the pressure at the rail connection before removing any lines or prepare for a face wash of gas.
I already have everything disconnected. I opened the gas cap to release pressure. I have pump and filter mounted and hosed together. I have tank line hooked the the bottom of regulator. The regulator is hanging in place for the night as i had enough and needed to eat. The motor line and pump line are yet to be hooked up and i got annoyed from trying to wrestle it.
