Old Mar 16, 2015 | 03:28 PM
PNA's Avatar
PNA
Default Re: transmission the does and don't (questions)
Originally Posted by Freezer
Please answer in the way they follow ty.
Background: washed my car the other day then decided to readjuat my headlights. When I shut the hood something sound different like something dell but I didn't see anything. Then I took it for a drive and engine light came on. The code was p0715. I have a automatic 2004 Chrysler crossfire coupé.
1.)how long of a dipstick do I need to make?
2.) What type of transmission fluid should I use.
3.) Its probably q faulty speed sensor, where is that located.
4.) Location of connector plate?
Please answer these. I've been searching the forum and its getting frustrating now.thanks.
Just some quick responses:
If the transmission is leaking, it may be from the transmission connector. It''s on the passenger side up on the side of the transmission. It is known / prone to leaking. It's a cheap part but it is also know to be hard to remove, but only if it gets stipped in the connector plate. If you can get it out, that would be great. About 50 dollars to repair.
The Transmission connector plate is inside the tranny.
Transmission fluid type is: See this post: https://www.crossfireforum.org/forum...d-replace.html
Fluid type info can be found in the manual. This post use Amsoil ATF
Not sure about the code and speed sensor relationship question. What are you asking?
