Old Mar 23, 2015 | 12:39 AM
Cerda-fied's Avatar
Cerda-fied
Exclamation Srt Turns over but does not run
Hello,
I was having battery issues last month and finally replaced the battery. Turned on a little rough and idled fine for a few minutes as i was cleaning up tools. Then it shut off and would not turn back on after trying a few times. Then tried to read codes and none were found. Checked RCM and all solder looked great but did three trouble areas just in case. Still not wanting to start up. Where do I go from here? Does crankshaft position sensor give trouble codes when bad?
Thanks,
