Old Mar 23, 2015 | 01:46 AM
Bay Cruise's Avatar
Bay Cruise
Default Re: Does this sound right re Autobox Torque Convertor
Originally Posted by syfi
The W5A580 is extremely sensitive to the quality of the transmissions fluid. Even with the slightest hint of water in the fluid (as low as 0.05%) the transmission can start shuddering. If you experience shuddering with your transmission, try changing out the fluid with new fluid and be sure to replace the internal filter, too.
Thanks syfi, the fluid was changed only 2-3 months ago with the filter when my 722.6 plate was replaced. The plug was also changed, but it did leak 3 weeks later from the new plug so he fitted new seals again and all been good for the last 4--5 weeks. Seems that this is common with these o rings, even new ones !!. No leak now all dry. I did get him to check the old level again this morning and it was all ok and clean as it should be. What you say syfi does now make me think humidity because we have had the most horridness humidity here for the last few weeks when it started and it is very intermittent which again is making me think the air is making a difference. Just hard to believe they are so sensitive.
