Old Apr 3, 2015 | 06:37 AM
  #262 (permalink)
onehundred80
Default Re: Crankshaft Position Sensor
Originally Posted by stevo1384
IM about to set this car on fire Hahaa. No codes!!!! Cranks but no fire, it used to fire up then die after one second. If I hit the gas before it died it would stay running changed all the spark plugs now it won't start at all it will crank two sometimes three times then nothing I triple checked the plug wires there on good. Still no codes unhooked the battery same scenario. Re sodered the joints on the RCM before changing the plugs it still ran after that IM thinking ignition switch maybe cause sometimes it won't crank. What should I do please help guys I really like my 06 roadster
Cranking two or three times then nothing and when you disconnect the battery you get a repeat of the same is a symptom of a failed SKREEM.
