Old Apr 10, 2015 | 07:04 PM
onehundred80
Default Re: TPMS 101, The Basics.
Originally Posted by MAYAman
Guys I just put some Brabus Monoblock V wheels on my car and the stock sensors collar was too large so I couldn't put the stock sensors on and my tire pressure light is tripped obviously. What pressure sensor do I need that will fit the Brabus wheels and will work with our car?
thanks
Are you sure?
The collar screws on to the normal sized stem from the outside, it does not go through the hole. The rubber seal is the same size as the old style rubber seal. This picture shows the rubber stem, ours use the metal stem that is screwed on from the outside, in either case the stem is put in from the inside and pulled into the hole just like the regular stems in the old days.
I'm not saying these ones work, 20028 work and they are AirAware series, these 330000 series should but have not been proven, they are shown for fitment look only.
