funnybunchofitalians
Thanks for the advice. Much appreciated. So far I have just swapped the internals into the ebay key and it works just fine. I put the uncut blade into the old key and hopefully someone is going to be able to cut it. When I took the key to Lowes and Home Depot, the people there were looking at my key as if it was some kind of rocket technology piece. They said that some complex tech is used to cut keys like this. To be honest I find it hard to believe.
I am assuming you transferred the little black chip from the old case to the ebay case, right ?
If so, then getting the blank key in the old case cut is a waste of time as it will be good only for manually unlocking the doors and glove box.
IT WILL NOT START THE CAR WITHOUT THE TRANSPONDER CHIP !!!
