Sorry. It has to have 2 things the Transponder programmed by Chrysler AND the circuit board for the buttons inside the fob programmed by Chrysler. You cant take the "button" board and just turn on key and "reset" the board from another car. The only thing any Ebay key is good for is to get the FOB shell but that's no good either because you have to break it open. You CAN get the replacement FOB shell and put your guts into. I was going to take the good Transponder chip and tape into the steering column and get more button boards from Ebay and copy as many Regular keys as I wanted but they got you one way or another. So the only way to get more fully functioning keys (Transponder and lock/unlock board) is to order one by the VIN and THEN do the turn key on and push buttons thing. Cutting the physical part of the key is easy with the machine, I can do that in my sleep.
https://www.crossfireforum.org/forum...-question.html
Franc Rauscher
With the cutting, EBAY, or with the programing?
Your risible non answer is no help
So what does work?
