Old Apr 17, 2015 | 09:04 AM
UrbanE's Avatar
UrbanE
Default Re: Double Din Project: Disassembling question
Is the audio shop going to fabricate all of the parts? It's not a big job but it sure does consume a lot of time with respect to finishing. I had to pull all of the console parts sand and paint them all to match.
Which head unit did you select?
I went with Kenwood DNX 771HD for nav, rear camera, xm, HDMI and Bluetooth. HERES. Tip if hooking up the HDMI just ground it to complete the circuit. Don't wire it to the parking break. If you wire it to the break, you'll only be able to use it when stopped and the brake engaged.
Btw you can also split the rear speakers from the front, there are lots of threads in the forum as to how to do this.
If hooking up the rear camera let me know and I'll tell you where the wire is located just outside the shifter
Send images
