Old Apr 18, 2015 | 10:04 PM
GraphiteGhost
Default Re: fan control module?
Originally Posted by GregWork
In this box above the passenger front wheel.
50A (Radiator Fan & Traction Control)
Mopar: 05135816AA
05135816AA Mopar NONE FUSE $3.97
FUSE. 50 AMP. Relays, Fuses, Boxes and related items made by Mopar. #05135816AA
BTW folks, remember this is a HOT buss. Don't let anything (tools or anything metal) 'skitter' across these connections to GROUND. Besides almost making you change your pants, it could be extremely expensive to fix. When replacing any of these fuses, it is a safe practice to disconnect your negative battery cable (and remember you might have to reset a few things like the seatbelt chime software 'off'). Also, your 'emissions drive cycle' may have to run again so don't disconnect the negative cable if your going to have to run an emissions test soon. Safety FIRST!
