Old Apr 19, 2015 | 09:00 PM
  #810 (permalink)
breakneck's Avatar
breakneck
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by keiranmcallister
I've spent several hours grinding the first pin as I could not turn my key whatsoever. Once I grind it down enough, I should be able to turn my key to position 1? Correct? I'm getting frustrated as I still cannot turn my key to finish the "sticky key mod" directions. I also bumped two plastic panels from my steering column and with them came a spring (right above the steering wheel lever for adjusting its position). Are these important? Don't think I can get those back in as its a bad angle. Thank you for any info, trying to get my new x fire in driving order.
Someone correct me if I'm wrong, but when I did mine, it seemed like that pin was only blocking me from removing the assembly from its housing. My key turned to position 1 but that didn't cause the pin to retract far enough, I still had to grind the pin down to basically nothing before the assembly would come out.
