keiranmcallister
I've spent several hours grinding the first pin as I could not turn my key whatsoever. Once I grind it down enough, I should be able to turn my key to position 1? Correct? I'm getting frustrated as I still cannot turn my key to finish the "sticky key mod" directions. I also bumped two plastic panels from my steering column and with them came a spring (right above the steering wheel lever for adjusting its position). Are these important? Don't think I can get those back in as its a bad angle. Thank you for any info, trying to get my new x fire in driving order.
