Old Apr 20, 2015 | 01:29 PM
  #812 (permalink)
keiranmcallister's Avatar
keiranmcallister
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Just got done putting everything back together. Key is turning and am 99.9% sure i put all three cables back correctly. Unfortunetly when i went to test the battery before putting the dash back together, my neg terminal is popping. I disconnected the pos then connected the neg then the pos again and still the same. Please help
Originally Posted by graphiteghost
i have one pressing question and two minor points to ask/highlight. The important one is 'how thick is the cast metal at the place your clamping at with the vise-grips'? If too much pressure is applied with the vise-grips, can it crush/crack the housing? Now on to the minor highlights, when you document the mod (great job btw) please be sure the next owner understands what your talking about. A reference to a more detailed write-up in say, the owners manual, or a separate sheet of paper, with detail exactly what a 'sticky key mod' is, could enhance that line on that fuse panel card (especially since it may be years until someone actually opens that cover). The final highlight, is also a sort of a question, how the he11 is that dual vise-grips/assembly standing up like that? It seems to defy gravity being the way they look stacked in that picture angle. Great job on your post btw!
