Old Apr 26, 2015 | 12:31 PM
pct's Avatar
pct
Default Re: Heated rear window .... Not
Originally Posted by para12239
Having a problem with my heated rear window. It has never worked since I bought the car 18 months ago.
Finally got round to looking at it but cannot understand the problem. I have had it tested by an auto electrician who has ascertained that power is getting to it but we cannot find any break in the element yet the circuit is not complete at other side of the element. I know next to nothing about auto electrics so do not know what else to try except maybe a different auto electrician !!!
Is this a known fault with Crossfires?
If you have power at the point of entry to the element but no continuity, then unfortunately although there might not be a visible break, it has to be the element itself.
Sounds like you need a window fitter not an electrician, it should be possible to buy a rear window from a breaker, (ask them to verify that the heater element works before they remove it) and then pay someone to fit it for you.
