Old Apr 28, 2015 | 10:27 AM
mlwest8783's Avatar
mlwest8783
Default Re: Convertible top WON'T CLOSE!
You are most likely low on fluid. That means you have a leak in the system as well.
I have already checked the fluid. It was at the minimum line so I topped it off and the fluid is good. I opened and closed the top manually several time so make sure there wasn't any air in the lines. Still have the problem
