johnlisa61
got the hydraulic fluid and filled the resv. Yahoooooo It worked. and its down now .. I'll keep an eye on the level... minor inconvenience...
Thanks...had to do it a couple times to get the fluid around
Now have new problem....spoiler wont deploy from the dash switch. On starting car red light goes on...it has worked ... I didn't touch anything related to it... Is there a reset???
Thanks again for all the helpful suggestions... and insight.
John L.
Glad you got it working again!
It kind of sounds like the same problem im having with mine. So you added fluid and it worked? Did you have to do anything to the top to get the fluid through out the system? My fluid was at the minimum line so I filled it up but that didn't do anything.
Here is what mine is doing, is this how your was?
