Old Apr 30, 2015 | 10:44 AM
GraphiteGhost
Default Re: Auxiliary air pump
Originally Posted by gedwar1
It must be a nightmare to be the poor smuck responsible for putting the right sticker on the right pump. Does the Mercedes pump which is indistinguishable from the Audi pump, including the only number on the two pumps, get a Mercedes sticker or an Audi sticker? I am glad I don't work for Bosch.
A tale of two GM plants... I had a 1989 Buick Park Ave, 3.6L FWD transverse motor. I needed a coil pack (one of the three dual plug coils) and went to research the Buick PA part number. The ONE coil at the time was $114.00 plus tax (and change, its been almost two decades). Now me being the el-cheapo I am and knowing the same motor was in the 89 Le-Sabre (and a multitude of other GM products) I went and researched the Le-Sabre part number. I got that coil pack brand new for 31 bucks (and tax/change). So, manufacturers do the part number/part switch many times, and the 'level' of market of the car makes a difference on what price you pay. The two coil part numbers were different BUT the part inside was absolutely identical. I believe proper homework should be done whenever ANY part number is substituted, just be aware they just might not work. I feel as 180, that if someone takes your post at face value without insuring the part is absolutely swappable, that monies may be lost for a variety of reasons (especially if anything was defaced/damaged in the attempt of making it work). I sure haven't spent that money for that particular part swap, so I cannot say for sure they are the same internally.
