Old Apr 30, 2015 | 03:16 PM
  #41 (permalink)
onehundred80
Default Re: broken supercharger
Originally Posted by amx1397
first ,yes the TC control light will flash at WOT with the TC turned off. second if the IC pump is not working , your SC will not in gauge, even though you can drive the car that way U just have no power. email Rob at Needwings for a new pump and you are good to go. one way to test the pump is when the car is cold the SC IC pump works great, then after 2 to 4 WOT jaunts, it has no power ,,,let it idle or shut it off for 5 min. then it works again,,,it is the pump! jim
The SC IC pump will in all probability not work at any point. Its spindle may be turning but the impeller will be broken into pieces and no longer attached to the motor spindle. The lack of power is due to the SC clutch not engaging due to the overly high temperature of the IC due to the lack of cooling.
The new Bosch IC pumps, with the part number 0392022010, have as yet not had problems.
