Old May 6, 2015 | 06:14 PM
  #69 (permalink)
onehundred80
Default Re: P0410 code check engine light
Originally Posted by janetsordia@yahoo.com
How do I reset my check engine light on my 2006 Chrysler crossfire?
You should explain what caused the light to go on and what was done to fix the problem. Your post above gives no clue to your problem, or if it was fixed.
In the past people have responded to questions like this and then been told that their answer was wrong because they had assumed certain things had or had not been done. The replies from the OP often were not too friendly. I mostly ignore this type of question as it has happened to me. After spending considerable time on an answer and then being told you are quite wrong is a bit upsetting.
Your question last year lacked info and was ignored as well.
There were to few facts included in the post.
Hi all,
I've recently replaced all four TPS sensors and the light remains on. What is it that I need to do now?
