Old May 9, 2015 | 09:14 AM
onehundred80
Default Re: Which module is it, help
Originally Posted by skarlet
Well i went to bleed the brakes and couldn't do it, took it to Tire Kingdom and they couldn't do it something about needing to pressure bleed them and needing to connect to the module in order to do it. had to take it to Chrysler, and they tell me that the module that I put in was no good. So bottom line is Tuesday Chrysler will be replacing my module and will program it and they say that there is an 80% chance that this will fix the problem. $1800 hopefully it will do so will post the results, these cars are a pain. it's my wife's car so I will try to get it fixed.
Why can't you bleed the brakes?
For the cost of $1,800 you get an 80% chance of a solution? Which means if it fails you are still out $1.800.
I doubt there is anything wrong with both modules.
