Thread: Please help
Old May 9, 2015 | 02:06 PM
GraphiteGhost
Default Re: Please help
Originally Posted by Senja
Disconnected the battery and let it sit... then plugged it back in and it was like new again.
Strangest thing I've ever seen with a car.
Thanks for your help though.
Senja
IF it is a problem with the RCM solder points, you'll be stuck again and again until you fix it. Keep this in mind ok? I would suggest you 'fix' the solder points before it happens again. The symptoms are a classic RCM fault easily fixed.
