Old May 11, 2015 | 08:16 PM
Chiminoul's Avatar
Chiminoul
Default Re: Front Indicator not working.
Originally Posted by boobles37
Just a quick update. Got the indicator working again by slightly bending up the contact on the housing where the bulb connects to. The contacts with in the headlight look burnt so not sure how long this fix will last as obviously something not right.
I have a similar problem. My right turn signal doesn't work and it is not the socket or a fuse issue.
How did you get to the connectors inside the headlight assembly? I can't seem to be able to get a good look inside where the socket connects to the headlight assembly.
Thank you.
