Front Indicator not working.
Old Apr 1, 2015 | 11:56 AM
boobles37's Avatar
Default Front Indicator not working.
Hi guys,
Well after 3.5 years of ownership of my Coupe I am still enjoying the car & hope to keep it for many years.
One thing has become a problem though & I was hoping somebody on here could help please.
Basically my drivers side front indicator has stopped working (the one situated with in front lights) & I have tested the bulb & it works fine. Can somebody point me in the direction of where this would be earthed as I think this would obviously need checking or is there something else I should be checking?
Many thanks.
Old Apr 1, 2015 | 01:18 PM
maxcichon's Avatar
Default Re: Front Indicator not working.
The contact(s) are most likely toast.
There is a thread here, somewhere, that shows a replacement unit.
Old Apr 1, 2015 | 03:10 PM
If you inspect the two contact points on the outside of holder, and the one's in the headlight and see no physical damage, try cleaning them with a pencil eraser.
If the holder contacts are arched/damaged, you can sometimes repair that with a little extra solder.
Old Apr 1, 2015 | 03:24 PM
boobles37's Avatar
Thanks for the replies guys. The contacts on both parts have been checked & cleaned up but still not working. In fact, the contacts look in really good condition.
Old Apr 1, 2015 | 03:39 PM
Travish's Avatar
Put your volt meter on the contacts and see if you have power. Probably not if they look good but you will be sure then.
Old Apr 1, 2015 | 03:43 PM
boobles37's Avatar
Good idea. Will give this a try tomorrow. Thank you.
Old Apr 1, 2015 | 07:03 PM
jimmirehman's Avatar
Default
Check the mini fuse box on the side of the dash with the driver side door open. There is a fuse that handles the right parking lights and a fuse than handles the left.
Old Apr 1, 2015 | 07:42 PM
The bulb/socket in question is the turn signal bulb, not a parking light.
Old Apr 2, 2015 | 02:05 AM
boobles37's Avatar
Having all of Easter off work this will give me 4 days to get to the bottom of this annoying problem. I hate it when people stare at me because they think that I am not indicating to turn right!
Old Apr 5, 2015 | 11:39 AM
boobles37's Avatar
Just a quick update. Got the indicator working again by slightly bending up the contact on the housing where the bulb connects to. The contacts with in the headlight look burnt so not sure how long this fix will last as obviously something not right.
Old Apr 5, 2015 | 02:05 PM
What is not right is the overall ****-poor design. Nothing you can do about it.
Old Apr 6, 2015 | 02:42 PM
boobles37's Avatar
Couldn't agree more. The crappy British weather also can make things "difficult" at times.
Old Apr 6, 2015 | 08:04 PM
eightball200's Avatar
I have had a similar fix working for about 3 months now. No indication of failure yet, dreading having to change that bulb now though.
Old Apr 7, 2015 | 02:25 AM
boobles37's Avatar
Not sure on prices over there for new headlight but over here they are about £600.
Old Apr 7, 2015 | 09:29 AM
What people forget is that parts like this were not made by Chrysler or Mercedes, they were made by a company that specializes in parts like this. So you try to get the part another way, the part has a number on it and the manufacturers name.
In this case the maker is Valeo and this problem has come up before, so using Valeo and turn signal in the Google search we get posts on the problem. I know that a Valeo part was found, if it actually worked in the end I cannot remember.
I found this part (CLICK) but someone said it did not fit even though it was the same part number. Compare the photo to your part.
Old Apr 7, 2015 | 03:45 PM
Just throw a $ on that figure and you've about got it. It's all good tho, I think I can fix it when it finally goes kaput. Also polished the lenses yesterday and they look almost new. Any recommendations on a good protective film?
Old Apr 7, 2015 | 04:23 PM
Xpel or Lamin-x, either one.
Old Apr 8, 2015 | 02:35 AM
boobles37's Avatar
Thank you for this info, very useful.
Old May 11, 2015 | 08:16 PM
Chiminoul's Avatar
I have a similar problem. My right turn signal doesn't work and it is not the socket or a fuse issue.
How did you get to the connectors inside the headlight assembly? I can't seem to be able to get a good look inside where the socket connects to the headlight assembly.
Thank you.
MiamiTVR
Jan 30, 2016 02:15 PM
Posimoto
Sep 13, 2015 06:13 PM
jaesa
Sep 7, 2015 01:50 PM
maxcichon
Sep 4, 2015 12:50 PM
toob
Aug 19, 2015 07:31 AM
