irboozer
Thank you for the quick reply Mr. Miata. You're right, it is bowed out. I tried to pry it back in with a 2 by 4 up against the tire, but to no avail. When you used the heat gun, did you take the tire off? Next time I will try and use a heat gun.
Yes took the tire off to have some working room. heated up the whole area.. about 18 inch diameter, then laid the 2x4 against it.
