Old May 14, 2015 | 09:15 AM
amx1397
Default Re: Killer Chiller Users - unite...updates please
Originally Posted by bdh
I AM HAPPY
With some help from Joe Kincaid I seem to have it working, iat is now around 60 - 62 degrees when driving around. Temp goes up slowly sitting at a light,
but I still may add some more refrigerant later which would make it colder. Current a/c pressures are at max but sometimes it can take a while to work thru the system.
If everything remains good I may remove the supercooler & put an electric fan in front that I can turn on when I am in the line up waiting to stage.
And yes I am making over 23 pounds boost
after reading post 21 i was sure you did something wrong, ,I had sent Joe Kincaid my install instructions and one of the points that i made was to add freon to make the system work like it is should.
on the highway you should have IAT's about the same as your mph,example 80 mph your iat's should be close to 80 . 60 to 62 will be in town or driving short distance or driving below 50 mph.
I have had mine in for over 3 year now and temps in fl. from 97* down to 40* and my iat's are always where i want them,
you know the AC compressor also runs when the heat is on so at 40* outside ,, and your Iat is too high turn on the heater and your iat will drop. here is a pic of my log from last night
