I searched some more and the final answer is yes and no.
By searching the springs in the catalogue of Suplex (
http://www.mladov.ru/katalog/suplex/..._2008-2009.pdf) I found out that the rear springs are identical, yet the front springs are not.
However, I used the Suplex part codes to get the dimensions from this (Dutch) site:
Veer vooras SUPLEX 19347 | MijnAutoOnderdelen.nl
Note: this spring is the correct N/A front spring, SRT = 19348 and rear = 19219
Weird thing about suplex though is that the rear springs are identical between the N/A and SRT. Is this correct? Front springs are a LOT thicker (1.5mm) and lower (25mm).
