Old May 16, 2015 | 11:34 AM
  #214 (permalink)
LVXF's Avatar
LVXF
Default Re: Valve cover leak...
Originally Posted by Thornh
Is there any trick to getting the breather covers off the valve cover? I attempted this repair a few months back, got all the screws out ok but was afraid of bending the breather covers when I attempted to pry them off the valve cover. It seemed to be needing an excessive amount of force to break the seal. It was the middle of the winter and I decided to give up for warmer weather. Any tips appreciated. - Thanks
I used a box cutter to score the seam between the breather cover and the valve cover (See dtinker's message earlier in this thread). I also remember warming up the engine for a bit, and that seemed to make it easier. I then used a 1/4" flat-blade screwdriver. On the driver's side breather cover, there is a slight overhang (lip) near the oil fill tube. I placed the screwdriver under that lip, held the screwdriver with my right hand and s l o w l y applied (lifting) pressure with my left hand near the blade. If you're tempted to twist the blade, look very carefully at the seam to make sure that the metal is NOT deforming. Aluminum and alloys are very soft, compared to steel. With luck, you should see the seam start to widen. Good luck!
Do NOT buy replacement screws from MB. They are 18mm and 2mm too long for this job! If you're using stainless steel screws, remember that aluminum will give before steel :-) I went with aluminum replacement screws. Replacement screws, steel or aluminum, will have Allen heads instead of Torx. I read somewhere in the MB forum to torque the screws to 4 Nt-m. This translates to 36 in-lbs. I used anti-seize on the threads so I only torqued to 30 in-lbs. As a test, I installed one of these screws in a nut, put it in a vise and torqued to 36 in-lbs, and the screw head didn't snap. As mentioned in several threads, the bigger E-bolts should be torqued to 7 ft-lbs or 84 in-lbs. I torqued to 80 since I used anti-seize.
