Old May 18, 2015 | 11:40 PM
onehundred80
Default Re: Caliper brake clips
Originally Posted by BibaResto
maxcichon, thanks for your reply, even though it wasn't what I wanted to hear.
Is there some trick to getting the end in the remaining hole? Sure not helped by it being bent downward. The closest I came to installing it (the unfortunately) correct way was with using needle nose vise-grip pliers.
How is the enclosed moly brake lube to be used?
Is brake bleeding on a car with ABS any different than with pre-ABS brake systems?
Have you read the Shop Manual, if not download it and look at the brake section. There is a picture of the spring in position.
The grease is to lubricate the wear surfaces unless it is anti squeal grease and that goes on the BACK of the pad.
Brake bleeding is the same. Change all the fluid while you are at it.
These cars have a soft pedal feel, I went through that question myself.
