Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
May 20, 2015 | 05:52 PM
827
permalink
KDW4Him
Nov 2011
1,287
29
Alma, MI
Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Quote:
GucciKiiD
Im stuck at the part where you have to drill the locking pin flat. I tried for an hour and i cant drill any of the pin out! Can anyone tell me the fastest way to drill it out?
Just to be certain because I have seen about every interpretation of the PDF. Your ignition is one that is stuck, right? If it is stuck then a Dremel tool has been reported as the easiest to get the pin removed. It will take time due to the angle you are working at. If your ignition is not one that is stuck then the pin will push in if the key has been left at position 1.
KDW4Him
View Public Profile
Send a private message to KDW4Him
Visit KDW4Him's homepage!
Find all posts by KDW4Him
